Combo Lathes
Milltronics ML Series combo lathes offer both manual and CNC operations for tool rooms and job shops. They can be configured with many options, bore sizes and bed lengths – including live tooling and C-axis. The ML Series Combo Lathes feature the Milltronics 8200-B Series control.
ML 16/40
The ML16/40 is has 17” swing and 40” length with a 2.05” spindle bore.  With an 18 hp, 4,000 rpm spindle it generates 124 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
Key Specifications >
ML 18/60
With generous swing of 19,” length of 60” and a 2.56” spindle bore, the ML18/60 is our most popular combo lathe.  Featuring a 24 hp, 2,600 rpm spindle it produces 255 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
ML 22/60
This machine is a great value with 23” swing, 60” length and 3.22” spindle bore.  The ML22/60 has a 24 hp 2,000 rpm spindle that produces 1,050 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
ML 26/40
A popular size for job shops and customers who re-cut aluminum wheels for automobiles, the ML26/40 has a 27” swing, 40” length and 3.22” spindle bore.  Featuring a 24 hp, 2,600 rpm spindle it produces 255 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
ML 26/80
The ML 26/80 features a 27” swing with length of 80” and spindle bore of 4.17” (other bore sizes available).  It has a 24 hp spindle motor, 1,600 rpm and achieves 1,250 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
ML 26/120
Often used for oil pipe and other energy applications, the ML26/120 has a 27” swing, 6.02” bore and 120” length.  The ML26/120 has a 24 hp spindle motor, 1,600 rpm and achieves 1,250 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
ML 26/160
With 160” length, 27” swing and 6.02” bore, this large machine tackles big work.  Featuring a 24 hp spindle motor, 1,600 rpm and achieves 1,250 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
ML35
Milltronics ML35 has a 36” swing and is available in 80,” 120,” 160,” 200,” and 240” lengths with a standard 6.02” bore (other bore sizes available).  It has a 35 hp spindle motor, 900 rpm and produces 1,850 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
ML40
Our largest combo lathe, the ML 40 has a huge 39.7” swing and is available in 80,” 120,” 160,” 200,” and 240” lengths with a standard 6.02” bore (other bore sizes available).  It has a 35 hp spindle motor, 900 rpm and produces 1,850 ft lbs. of torque.  Standard with an 8 station electro-mechanical turret.  Options include chucks and chip conveyor.
Machine Model Swing Length Bore Spindle RPM HP/Torque Turret Weight
ML 16/40 17”/40” 2.05” 4,000 rpm 18 hp/124 ft lbs 8 electromech 6,000 lbs
ML 18/60 19”/60” 2.56” 2,600 rpm 24 hp/255 ft lbs 8 electromech 8,500 lbs
ML 22/60 23”/60” 3.22” 2,000 rpm 24 hp/1,050 ft lbs 8 electromech 10,000 lbs
ML 26/40 27”/40” 3.22” 2,000 rpm 24 hp/1,050 ft lbs 8 electromech 9,500 lbs
ML 26/80 27”/80” 4.17”* 1,600 rpm 24 hp/1,250 ft lbs 8 electromech 11,500 lbs
ML 26/120 27”/120” 6.02” 1,600 rpm 24 hp/1,250 ft lbs 8 electromech 13,200 lbs
ML 26/160 27”/160” 6.02” 1,600 rpm 24 hp/1,250 ft lbs 8 electromech 17,200 lbs
ML35 36”/80,” 120,” 160,” 200” & 240” 6.02”* 900 rpm 35 hp/1,850 ft lbs 8 electromech 23,000 lbs**
ML40 39.7”/80,” 120,” 160,” 200” & 240” 6.02”* 900 rpm 35 hp/1,850 ft lbs 8 electromech 24,500 lbs**
