Tool Room Mills
Milltronics has a long history of building tool room mills that can be run as manual, teach or full CNC with thousands of satisfied users.  Popular in tool rooms, job shops and tool & die, these machines are very flexible and can be used for a wide variety of different parts.  We offer two types of quill machines, in a traditional knee style as well as a bed type.  The rigid head (RH) machines are available in four different sizes starting with a compact 30” x 17” model up to a large travel 78” x 33.”  Milltronics tool room mills are fitted with the 8200-B Series control.
TRM3016
The TRM3016 is a tool room mill that offers large travels, speed and power at a great price. The TRM3016 features the 9000 DGI WindowsTM CNC control. A unique feature of the TRM Series is the “drop down” door openings that allow long part pass through to help accommodate oversize parts.
Key Specifications >
VK4II
The VK4II is a CNC knee mill with the unique Milltronics MillSlideTM that provides greater rigidity and more spindle nose to table top than conventional knee mills.  With 33” x 15” x 5.25” (MillSlideTM), 16.5” knee and 5.9” quill travel, the VK4II can be run as manual, teach or full CNC.
MB20
With generous travels of 40” x 20” x 24” and 6” quill, the MB20 has a 54” x 16” table and handles a wide variety of work.  Equipped with same control technology, electrics and servo systems as our higher end machines.
RH20
The Milltronics RH20 is our post popular tool room machine with a machining center head and an open bed frame.  Travels are 40” x 20” x 24” with table dimensions of 54” x 16” and 2,500 lbs. table capacity.  Available with optional 24 station tool changer.
RH30
With generous travels of 60” x 30” x 28” and a 73” x 24” table, this open bed mill has a 24 hp 8,000 rpm #40 taper spindle and produces 250 ft lbs. of torque.  Available with an optional 24 station tool changer.
RH33
Our largest open bed mill, the RH33 offers travels of 78” x 33” x 28” and an 86” x 32” table.  This huge machine features a 24 hp 8,000 rpm #40 taper spindle which generates 250 ft lbs. of torque.  Available with an optional 24 station tool changer.
Machine Model Travels Table/Capacity Spindle (Belt) HP/Torque ATC Weight
TRM3016 30” x 16” x 20” 35.4” x 16”/992 lbs 8,000 rpm #40 taper 15 hp/67 ft lbs 16 carousel 6,835 lbs
VK4II 33" x 15" x 5.25" x 6" (quill) 54" x 12"/1,500 lbs 3,900 rpm #40 taper 7.5 HP/79 ft lbs NA 4,400 lbs
MB20 40" x 20" x 24" x 6" (quill) 54" x 16"/2,500 lbs 4,000 rpm #40 taper 10 hp/300 ft lbs NA 7,000 lbs
RH20 40” x 20” x 24” 54” x 16”/2,500 lbs 8,000 rpm #40 taper 24 hp/85 ft lbs 24 carousel (opt) 8,000 lbs
RH30 60” x 30” x 28” 73” x 24”/3,000 lbs 8,000 rpm #40 taper 24 hp/85 ft lbs 24 carousel (opt) 11,000 lbs
RH33 78” x 33” x 28” 86” x 32”/3,000 lbs 8,000 rpm #40 taper 24 hp/85 ft lbs 24 carousel (opt) 15,000 lbs
Scroll to view more specs.
Build-a-Quote
