General Purpose VM Series Vertical Machining Centers
VM Series vertical machining centers offer a great combination of features and performance at an attractive price.  Designed with a process that is ISO 9000 certified, they are belt-driven and include as standard features such as full enclosures, swing-arm toolchangers, 10,000 rpm BIG-PLUS dual contact spindles, the latest 9000 Series control and more.
VM2515
The Milltronics VM2515 is our most compact VM Series machine with a space-saving footprint yet generous 25” x 15” x 20” travels with a 30” x 16” table and much more
Key Specifications >
VM3018
With a 34” x 18” table (table width matches the Y-travel) this 30” x 18” x 20” machine packs a 20 horsepower spindle motor and 10,000 rpm BIG PLUS spindle and more
VM4020
Our most popular size machine, the Milltronics VM4020 gives you 40” x 20” x 20” travels, a 46” x 20” table, a 20 horsepower spindle motor, 10,000 rpm BIG PLUS spindle and much more.
VM5020
For only a few dollars more than the VM4020, the VM5020 add 10” more X-travel.  With a 52” x 20” table and travels of 50” x 20” x 20” this machine is a great value.
Machine Model Travels Table/Capacity Spindle (Belt) HP/Torque ATC Weight
VM2515 25” x 15” x 20” 30” x 16”/1,500 lbs 10,000 rpm #40 BIG PLUS® 15 hp/54 ft lbs 20 Double Arm 6,200 lbs
VM3018 30” x 18” x 20” 34” x 18”/1,750 lbs 10,000 rpm #40 BIG PLUS® 20 hp/75 ft lbs 20 Double Arm 9,040 lbs
VM4020 40” x 20” x 20” 46” x 20”/2,000 lbs 10,000 rpm #40 BIG PLUS® 20 hp/75 ft lbs 20 Double Arm 9,500 lbs
VM5020 50” x 20” x 20” 52” x 20”/2,000 lbs 10,000 rpm #40 BIG PLUS® 20 hp/75 ft lbs 20 Double Arm 10,000 lbs
Scroll to view more specs.
Build-a-Quote
